density change
density change
In NX6 , I've edited the density of a couple of my custom materials,
The only way i can get parts that have that material, to update to the correct weight, is to open the material proporties dialog, delete the line with that ticked material, then re-pick the material (it re-appears at the bottom of the list), and then select the body.
I guess it's because when you pick a material out of the library, it brings it into the part (breaking the link)
Is there any way to update all of these parts, without opening each one and doing this?
RE: density change
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
RE: density change
Even with a journal from the assembly, or grip etc, etc ?
RE: density change
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: density change
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: density change
Thanks for your help
RE: density change
John R. Baker, P.E.
Industry Sector
Cypress, CA
