What came after moment distribution method?
According to http://en.wikipedia.org/wiki/Moment_distribution:
From the 1930s until computers began to be widely used in the design and analysis of structures, the moment distribution method was the most widely practiced method.
What is the best method to use to analyze two dimensional frames with computers?
I need to program a method from scratch that analyses beams that are similar to the one in the Wikipedia article above.
RE: What came after moment distribution method?
http://n
You should find the next post in the series as a pingback in the comments, or just search the blog for "frame analysis".
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
multi-span beams can also be solved as a redundant beam, whihc would point you towards unit load method, etc
working it out for yourself teaches you something (possibly to buy a canned program next time !?) but it makes you really understand the theory.
Mike McCann
MMC Engineering
http://
Doug Jenkins
