Plastic container and cap problem
hello, i`m having a problem with a plastic container we manufacture and its cap. the container (300 mL)is PP made by blowmolding. the problem consist in a overlap when I apply some force to the cap. i checked the diameters of the container screw and are the same of another container with diferent form, capacity(600 mL) and dimensions which use the same cap.
RE: Plastic container and cap problem
Mike Halloran
Pembroke Pines, FL, USA
Um, trying to envision this, but as Mike says, a drawing or sketch or photo would probably help a lot. If this "overlap" is occuring when you tighten down the cap, and the threads bind on the bottle...is there supposed to be a gasket under the cap, and if there is one, is it the right thickness?
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
