Static Seismic - piping across structural expansion joints?
I need to analyze several piping systems that cross a structural expansion joint and is in a seismic region (I am specifically required to perform a static seismic analysis).
When the building is one structure, I have no problem applying the Uniform Load to the entire system and including the appropriate displacements at the restraints (C-nodes) and building the appropriate load cases for the building moving together.  However, the Uniform loads are limited to 3 vectors and I have a single vector assigned to each direction (I use Z for vertical):
UX1=0.171 (positive East)
UY1=0
UZ1=0
UX2=0
UY2=0.171 (positive North)
UZ2=0
UX3=0
UY3=0
UZ3=0.046 (positive vertical)
I have a structural expansion joint running east-west and I would like to segregate the uniform loads and displacements to each half (north and south) so I can analyze a whole piping system and represent building/seismic movements independently (through load cases).  Obviously, I want to make sure my piping is supported properly and expansion loops designed properly for the worst cases when each half is going to be moving in opposite directions (compression/tension AND twisting).  I would need to be able to add more Uniform Load vectors to accomplish this.
Has anyone come across this before?  This "idea" should be able to be applied to piping between buildings, between buildings and highlines, and between highline sections at air gaps.
I appreciate any/all help.
Pat
