Steam Seperator : With flanged Drain:
Does anyone know of a steam seperator supplier that will allow a unit with a flanged drain? rather than a screwed fitting..
we want to use a unit for a liquid knock out but on a process service..
e.g. as a knock out drum..
but we need flanges for our 300 lb pipe spec on all connections,.,.
RE: Steam Seperator : With flanged Drain:
yes.. all drains are screwed fittings.. the inlets and outlets are flanged..but not drains..
Armstrong International will do this, but it is special-order.
Google Wright Austin Separators to see if they can do it.
rmw
Also Circle S, in Detroit, will fabricate a custom separator for you.
