Versa matic dome double diaphram pump
   Has anybody had experience with this make of pump ?
When I went to change the diaphrams , the first side was fine.
The diaphram is fixed between two metal plates secured by a stud attached to the outside plate ( which screws into the common shaft)
To change the other diaphram you need to push the common shaft through to the other side so you can secure this diaphram to the other side of the common shaft.
This side can then be enclosed.
The problem I have is that the first side diaphram is not flush now,having been pushed inwards towards the other side so enclosing this side is a problem .
Any ideas appreciated.
Sorry about description but I am not an engineer.
