I Need simple MAOP
I Need simple MAOP
I Need simple MAOP
Guys any simple calculation here is what I got
Pipe Wall Thickness in mm
Pipe Size
API class Grade
SMYS
By this details can someone give me a calculation for MAOP.. most of the pipe are 30 years old
RE: I Need simple MAOP
what codes apply and what fluid is it?
I think you need one additional piece of information - the original test pressure. Once you have that, you will have to de-rate the MAOP based on the remaining wall thickness.
dcastro
fluid is 3phase oil,water,gas
SeanB
I got the wall thickness as per the latest UT survey.. any simple formula will be a great help
