brake booster and master cylinder adjustment
RE: brake booster and master cylinder adjustment
You are bringing back old memories.
Yes, there should be a small amount of clearance between the brake rod and the master cylinder piston.  This will insure that the piston in the master cylinder will allow the fluid to return to the reservoir.  You can check by looking in the reservoir when the pedal is release.  You should see the fluid return, it shoots back so watch your eyes!
Cheers
