emergency diesel generator
I want to design an emergency panel board for diesel generator ,but i have a
problem to automatic starting the diesel, i don't know that for avoidance to
breaking gears of the starter motor what signal must be applied to stop
starter motor from starting after the diesel running?, can i use a Centrifugal relay
on the diesel or an over/under voltage relay on the output voltage of generator?
RE: emergency diesel generator
http://www.ecu-engine-controls.com/
I keep one of their 9988N engine controls and a SS40 speed switch on the truck all the time.
Hope that helps, Mike L.
I have used both DSE and ECU with good results.
The Dynagen stuff is nice, I especially like the 400Plus, heck of a package for the price, I have a job coming up I'll try one on.
Thanks for the link!
Mike L
