Convert 3d mesh into 3d solid
I know how to convert a solid into a 3dmesh, and a 3dmesh into lines, but does anyone out there know how to convert a 3dmesh into a solid?
RE: Convert 3d mesh into 3d solid
Dear moknows,
There is no command in AutoCAD to convert a 3D mesh to solids, but if you access the Mechanical Desktop, you can convert the mest to surfaces using the AM2SF command, convert the resulting surfaces to a part using the AMSTITCH command and at last convert the part to 3D solid using the EXPLODE command.
Farzad
I think that I got a lisp routine that would do that, called m2s.lsp, from accustudio.com
If you go to their site, and search for m2s.lsp, it'll take you to it.  Haven't tried it, but a friend told me that it worked without too much trouble.
Thank you for your responses.  My main intention was to turn a drawing full of 'closed' poly meshes into solids so that the file size would not be quit as large.  Currently these drawings are 40mb+.
I do not have Mechanical desktop, and the m2s lisp is a handy little tool, but appears to only work on 'open' meshes.  So I have not been able to make it work yet.  Your ideas have been great.  Thank you.
