What is the standard formula of rebar development length in columns?
Please post the formula of Ld of rebars of vertical structural elements as per latest ACI CODES.Which formula of Ld in tension or compression to be used.Thanks a lot elements
RE: What is the standard formula of rebar development length in columns?
ACI 318-05 (and -11) lists these requirements in sections 12.2-12.3.
The requirements are complicated enough that it can't be summarized here.  The controlling condition (tension or compression), depends on the design.
