Modelling heat flux in axisymmetric geometry
Dear Ansys experts/users
I would be highly grateful if anyone could explain to me why the attached (short and simple) code doesn't work! The problem apparently is related to applying heat flux and convection BC's. If you run the code with fixed temperature BC's, it works perfectly.
Many thanks in advance,
Kate
Kate
RE: Modelling heat flux in axisymmetric geometry
//signed//
Christopher K. Hubley
Mechanical Engineer
Sunpower Incorporated
Athens, Ohio
