Useful geometry out of Catia for 2D pattern cutting
I have been struggling to get good, usable 2D flat pattern data out of Catia for 2D NC cutting. We use Sigma Nest to optimize our material usage and programming for the Water Jet and we have always sent DXF files to it regardless of the originating CAD system. The DXF files created by Catia are virtually useless (gaps and overlaps) while DXFs out of Unigraphics or Rhino work great.
It is inconceivable to me that I can't use my data directly out of Catia without having to leapfrog it thru UG or Rhino first.
PLEASE, PLEASE anyone; tell me how you deal with this issue! And no I don't have any Catia MFG licenses.
RE: Useful geometry out of Catia for 2D pattern cutting
I use dxf out for water jet. I think it's how your geometry is created. I intersect my data to a plane to get a clean section. I will project any additional data if the section plane did not cut through the furthest most point.
Derek
Iges files works but it seems to be quite a bit larger in data size which slows the nesting program down. We just got a new machine for the programmer that has 64 bit win 7 and 12 gigs of RAM. Hopefully that will make a difference on the data usage side and I wont have to convert my Iges file to DXFs
