Abaqus CFD co-executions
I'm doing some simple abaqus/cfd coupled to abaqus/explicit co-executions which are working fine. but when I try to do a parallel execution (splitting it onto a couple of domains) it will just fail. This is the same co-execution files that ran sucessfully before I attempted parallelization.
As far as I can tell from the abaqus manual it is possible to do a parallelization with these co-executions, but maybe I'm wrong, as I am pretty new to abaqus?
Its something I'll need when I move onto bigger models.
Anyone have any experience with this?
Thanks!
RE: Abaqus CFD co-executions
Hi Rob, thanks for your reply. Yes I should have enough tokens, but as far as I know each time I do this simulation as well as using tokens for the solid and fluid jobs it also uses a co-simulation license and I think we may only have one which I'm guessing isn't enough when I try to run it in parallel?
In any case, this is the error I get
"The executable C:\Program aborted with system error code 65533."
