Just a simple macro. Error running in batch mode
Hi everybody,
I'm just starting working with CATIA macros, and I wrote my first CATScript. Just a simple one to open CATIA and to create a new part document and activate it. Please, see below the code. The problem is when I try to run it I get two errors. The first one, when I write in the command line
cd "C:\Program Files (x86)\Dassault Systemes\B19\intel_a\code\bin" CNEXT.exe -batch -macro "C:\Users\mjorge\Documents\iWork\Test.CATScript"
(believe me the path is correct) the message I receive is "The filename, directory name or volume label syntax is incorrect"
The second one, if I just click twice the CATScript file to execute it, it seems there is an error in line 29, the one in which appears Sub CATMain()!! How can it be wrong?? Any idea??
Thanks in advance...
Language="VBSCRIPT"
' Open CATIA Application
Function OpCATIA() As Object
    Dim CATIA As Object
    Set CATIA = CreateObject("CATIA.Application")
    CATIA.Visible = True
    Set OpCATIA = CATIA
End Function
' Create and activate new Part Document
Function GetCATIAPartDocument() As Object
    Set CATIA = OpCATIA
    Dim AuxPartDocument As Object
    CATIA.Documents.Add("Part")
    CATIA.Documents.Item(1).Activate
    Set AuxPartDocument = CATIA.ActiveDocument
    Set GetCATIAPartDocument = AuxPartDocument
'MAIN PROGRAM
Sub CATMain()
End Sub
RE: Just a simple macro. Error running in batch mode
Sorry, the End Function of GetCATIAPartDocument() is missing. However, in line 16, it gives the message:
Object doesn't support this property or method: 'CATIA'
Why?
