Grass Fire & Vessel Overpressure
I am revalidating safety valves at a rail car unloading facility.
It has four tiers of structure that contains equipment associated with unloading operations.
The facility is isolated. The closest source of flammables is a building 125-ft away.
The liquids being unloaded are absolutely not flammable nor combustible.
All the major equipment have safety valves based on external Fire.
The only credible external Fire I see is a grass Fire.
The classical external Fire is a "pool fire". I have also made some evaluations based on "jet fire" exposure.
The current work is neither pool fire nor jet fire.
Is 'grass fire" a credible overpressure scenario?
RE: Grass Fire & Vessel Overpressure
David
