Create sub assembly from parts in main assembly?
Hi all,
I've got a assembly with quite a few parts in it, and I want to combine some of the parts into a new sub-assembly.  I can do this on SolidWorks, but not too sure how to do it on Inventor. Any help would be great.
I'm using Inventor 2012.
thanks
IWF.
RE: Create sub assembly from parts in main assembly?
Ctrl select the components.
Right click and select Component>Demote and follow the on-screen Prompts.
if you select the parts you wish to Demote followed by Tab, Inventor will open the an assembly window.
btw i made a recent switch from SW to Inventor ( for work reasons, and altough at first i was not convinced, i have come to really appreciate Inventor.
Good luck
-c
