Create points in ABAQUS to apply concentrated loads
Hello!
I'm medelling a Reinforced Concrete slab in ABAQUS. I'm using SHELL element in a 3D space of model.
I have to apply some concentrated forces in points that aren't geometry points.
How can I create new points in ABAQUS (entering coordinates) to apply concentrated loads?
Thank you
Thank you
RE: Create points in ABAQUS to apply concentrated loads
Maybe a datum point also works, but I think it won't work.
Good luck!
With a partition I can't click points that I need because they are in very different position of the plane.
A DATUM POINT doesn't work because ABAQUS tells me that is an error: a datum point isn't an internal point of the geometry.
Anyone knows a solution?
