Fortran Vs C
Fortran Vs C
Fortran Vs C
Anyone have a good test to prove that FORTRAN is faster for math than C?
RE: Fortran Vs C
Most people won't have straight out "code" for you to test personally if that is what you are looking for.   There exists a lot of results of more professionally done test on the web that bear out that in "general",  fortran is "usually" faster for math related stuff.
I've written stuff in Fortran that has been a LOT faster than some other peoples codes.  However...  they used their algorithms and I used mine.    Mine may have been faster just because I was using a better algorithm technique.   Such things as this tell nothing about the language itself.
On a side note...  I have ( just for fun )  tested Fortran against VB on several different occasions...  both for numerical and non-numerical ( read, lots of string processing ) codes.    The Fortran has always been at least 20% faster and has sometimes been several hundred percent faster.
Dan
www.dtware.com
