How can I multiply feedrate by a factor in UG post
I have tried to apply Custom Command PB_COM_FEEDRATE_NUMBER, "set mom_sys_frn_factor 10.0", but all the feedrates keep same number as before, I can read TCL but how can make it work ?
RE: How can I multiply feedrate by a factor in UG post
I think this is only when feedrate is output as FRN (inverse time).
I would try adding this to PB_CMD_before_motion
global feed
global davidtan20feed
set davidtan20feed [expr $feed * 10.0]
Then change the F in linear move and circular move from $feed to $davidtan20feed
thank you so much, I really appreciate it.
