Edit 3-D Sketch
Edit 3-D Sketch
I am new to solid works 3-D sketching. I am up to speed on sketching but am at a loss on how to modify the dimensions I add to the sketch. I double-click dimension with no luck. Any help would be appreciated.
RE: Edit 3-D Sketch
RE: Edit 3-D Sketch
It took a minute to figure it out..lol.
Thanks for the reply
RE: Edit 3-D Sketch
Thanks.
RE: Edit 3-D Sketch
You stated you are new to SWX 3D sketching. I suggest you invest in some time to study the tutorials, Help files and online resources.
Next , you might look at what you are trying to do and see if the 3D sketch is the best way to go. I have been using SWX since it came out and in all honesty I rarely need to use a 3D sketch. For one thing 2D sketches are dramatically easier to work with and for another thing I've found that most of what I need to do can be done using the 2D sketches.
Good luck.
- - -Updraft
RE: Edit 3-D Sketch
I almost always use 2D sketches to create and control 3D sketches.
If you can tie a knot .....http:/
Attach here what you have completed so far.
RE: Edit 3-D Sketch
Dan
www.eltronresearch.com
Dan's Blog
