Drafting Vertical Dimension with No Leader
I'm trying to create a vertical dimension in NX7.5 drafting. When trying to place the value for the dimension outside of the arrowheads, I want the dimension to appear centered above the arrowheads without a leader. When I try to remove the dimension leader in dimension style menus, I end up with the picture attached. Is there a way to get rid of this weird offset and how do I implement this change into my drafting standard. Thanks
RE: Drafting Vertical Dimension with No Leader
After all, one the values of the Eng-Tips Forum is that you can flag a thread thus putting a link to it in your personal archive so that in the future this can be referenced if the need arises again. I've done that with many of my own posts, where I suspect that this topic will come-up in the future and so why should I have to regurgitate a response from memory again. I also tag other peoples posts who have given me some good ideas or who have provided a well thought-out answer for something which I'm sure will be a topic of discussion here in the future.
So post what you learned and allow the rest of us to benefit from it
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
John R. Baker, P.E.
Industry Sector
Cypress, CA
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
