Reuse library and pasting a sketch
Hello all,
cannot understand how to create a sketch and then use it in reuse library? If i simply create a sketch, place that *prt file in reuse library folder and trying to paste into model, it cames as new component. how to avoid this?
nx7.0.1.7 64bit
win7 64bit
thanks
RE: Reuse library and pasting a sketch
Thanks for the answer, but please take a look at the attached picture. Seems that RMB menu differs from yours. why? I can manualy create directorys from windows explorer, NX see them in the browser window, but option "add reusable object here" is grey.
Thanks.
Attachment:  http://dl.dropbox.com/u/20259604/test1.jpg
So can anyone explain how to create reusable sketch?
Could it be problems with security settings with windows?
Be careful, you did'nt created your own folder under 2D SECTION LIBRARY.
Didier Psaltopoulos
http://www.psi-cad.com
But how to create it? using windows explorer, o from ug? look at the attached picture (my previous post). there are no option like "create folder".
You are right "2D Section Library" is new in NX7.5. Unfortunatly, I didn't have NX7 installed.
Didier Psaltopoulos
