How do I delete a drawing sheet attribute that I created.
Hi Guys, Me again,
I created a drawing sheet for use in NX 7.5 and I placed down this attribute: <W@$SH_MASTER_PART_NAME>
Everything works 100% as it reads and populates the models part name, but now I want to delete this attribute.
And my problem, is that when I open the Drawing sheet template to edit it, I cannot see this attribute as it is typed, it's as if it's hidden and only displays when reading the model name, how do I select it so that I can hit the delete button?
Thanks in advance!!
RE: How do I delete a drawing sheet attribute that I created.
BTW, we don't refer to these types of text entries as 'attributes'.  Attributes are something different altogether.  Something like <W@$SH_MASTER_PART_NAME> is an example of what we call 'Automatic Text'.
Now back to your 'problem'...
OK, open your Drawing Template file in Modeling, NOT Drafting, and then add any other part file as a Component.  Now swtich to Drafting and turn on the display of the Drawing and you will see your note showing the name of the part file you just added as a Component.  Select and delete the note.  Now go back to Modeling, DELETE the Component and then save your Drawing Template file.  You should be good to go.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
Thanks John, sorted!
