Ductile Irons
Ductile Irons
Ductile Irons
What is the difference in ASTM A395 vs A536 60-45-12?
Specifically I am interested in why one over the other (irregardless of the small increase in strength). My interest is in valve or fittings. I know that A395 is very commonly used and elevated temp data is also available, but not so for A536.
My use would be from -20F to +650F.
RE: Ductile Irons
For valves and fittings, you should be using ASME B16.42 for material, and this references ASTM A 395. Why? Because using a known standard like ASME B16.42 "Ductile Iron Pipe Flanges and Fittings" has been proven for use in service.
RE: Ductile Irons
A395 castings are rated for elevated temperature while A536 are for general use at ambient temperatures.  For your application you should not even be thinking of A536.
Aaron Tanzer
www.lehightesting.com
RE: Ductile Irons
Great replies to both of you.
Thanks for taking the time
