Countersink dim
Countersink dim
The question is Countersink dim. for a 4-40, 100 deg. c'sink
Helical sharp dim. for this screw is .225
print size callout is .231 + - .005 = .226 to .236
is this a aerospace standed
the low end seams to close to helical Max dim. of .225
or a case of lazy engineering, just use = + - .005
RE: Countersink dim
What's the assembly condition, fixed or floating?
What's the primary design consideration, flush head?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Countersink dim
+ - .005
Fixed
Flush
RE: Countersink dim
If .005 this corresponds to pos tol dia .014 (give or take a tenth of a thou)
So, to guarantee flush you need the minimum counter sink size to be the 'max sharp diameter' of the screw head, + pos tol of csk hole + post tol of threaded hole.
So if your numbers and my assumptions are correct that'd be:
.225+.014+.014 = .253 minimum.
My guess, it's a case of lazy/uneducated engineer.
Note - that while this guarantees flush, it does not optimize stress under the head or anything else, just guarantees the head should always be flush or below flush.
RE: Countersink dim
You put in black and white the hole picture as I also see it
Dockken
RE: Countersink dim
Are you in a position to go back to the person that came up with the .231+-.005 and question/educate them?
RE: Countersink dim
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
RE: Countersink dim
If I get an opportunity will try, but they are reluctant to change
RE: Countersink dim
Plus the head of the screw and/or the material it's going into probably deform a bit.
Plus, unless they're really looking for it they may not notice heads just a few thousandths above flush.
However, there are situations where not being truly flush, or generating more stress under the screw heads can be a real problem.
RE: Countersink dim
Generly around 1/8 covers, done manualy
no fun
using
Micro-Stop Countersink Units
http://www
Dockken
RE: Countersink dim
RE: Countersink dim
dockken
