Display text in place of tolerance in GD&T
I have a "master" drawing that describes three pipes of different lengths. Each pipe will have a different straightness tolerance, and I'd like to have a straightness GD&T box with "See Table" or "S" instead of the numerical tolerance.
Is there a way to do this? I know on a dimension you can modify it by putting an "o" after the "@D" and then typing your custom text, but I can't get it to work in the GD&T box.
Oh yeah, and I'm using WF4.
Thanks in advance!
Thanks in advance!
RE: Display text in place of tolerance in GD&T
@[(Straightness symbol)@]@[ S @]
If anyone knows a way to modify the actual GD&T I would still love to hear how to do it, but I at least have a workaround if it isn't possible.
