Adhesive Required
Adhesive Required
Adhesive Required
We are using an EPDM or Butadiene Styrene closed cell foam for gasketting some cofferdams.
Can anyone recommend an adhesive for the above foam to steel? The envirnment will be total immersion for several months at a time.
Dik
RE: Adhesive Required
Thanks, Mike... I'll look into this material for next year.  The cofferdams are temporary this year to be properly coated for long term usage.
Dik
What about Marine 5200?  It glues metal to fiberglass like nobody's business, and it's got some give to it so deflection won't tear it up.
Just an idea.  Never used it in an engineering application before, but my boat doesn't leak.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
3M 5200 does work very well indeed, but it's not sticky like the weatherstrip adhesive.
Once cured, it's unbelievably adherent, but until it cures, it's rather slippery, and squeezing the joint will cause the rubber to ooze out unless it's mechanically restrained.  It also takes a couple of days to really cure.
Mike Halloran
Pembroke Pines, FL, USA
Thanks Mike... be looking at the environmental issues, first...
Dik
