What's a P.F. counterbore??
Hello, I received the attached view from an outside source and can't figure out what they want with a P.F. counterbore. I know I'll kick myself when I get an answer. Does anyone know what this means? Thanks!!
Mechanical Engineer
Field Forensics, Inc.
Engineering isn't about perfect solutions; it's about doing the best you can with limited resources. - Randy Pausch
RE: What's a P.F. counterbore??
They want to press a plug in the c'bore to seal the .234 hole below.
Ben Loosli
It should be made more clear, call out the tolerance instead of relying on the machinist making it press fit.
Chris
SolidWorks 10 SP5.0
ctopher's home
SolidWorks Legion
Mechanical Engineer
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
