United Promoted bodies and BOM
Greetings,
I have run into an challege with model I recently made. I assembled some components in a file and then promoted them so I could add fillets and cuts for machined features. A problem has come up in the drawing since I had to unite the promoted bodies so I could do some of the operations. The problem is with component callouts. The BOM shows all the components that are used to make the assembly, but since promoted bodies are united all the balloons will come up with the same item number.
Any ideas on how to work around this issue?
Chris
NX 6.0.5.3
Windows XP 64-bit
Chris
NX 6.0.5.3
Windows XP 64-bit
RE: United Promoted bodies and BOM
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
I don't exactly know what you mean by keeping the target and tool bodies. Can you elaborate on that more?
Chris
NX 6.0.5.3
Windows XP 64-bit
Chris
NX 6.0.5.3
Windows XP 64-bit
