Disappearing welds/sections?
Hello, We are running NX 6.0.5.3 and the other day I cleaned up a drawing with numerous components detailed The drawing was 3 pages long and had sections and a few sub assemblies some had welds. Coming in on Monday morning and I opened the drawing up to find weld symbols only had the leader and an empty weld line no tail and no notes. Also the sections on the prints were missing cross section arrows on the print. Section letter remained but the cut arrows are not there. A colleague opened the print as well and it opened fine. I closed the print and then reopened it everything looks fine. This has happened a few times. What happens if someone down the road opens the print and updates a dimension and prints the drawing off without realizing the missing items? Anyone have these issues as well? Any solutions?
RE: Disappearing welds/sections?
edit (pull-down) > view > update views > select all the views that are listed, and make sure "show all views in drawing" is toggled on > press apply
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
If the section line is still not showing up properly then edit it and move a segment to its cut position - sometimes if the point that it was attached to is no longer there then it falls off.
