Testing & Inspection of Electrical Wiring
Is testing and inspection of electrical wiring including underground cables for houses in a residential area required by any code?
Our maintenance crews perform the required Preventive Maintenance works for all electrical equipment in the residential area.
We were asked by our Safety Group to test and inspect all wiring including underground cables to make sure they are in good shape. This would include checking wiring throughout the houses behind walls and in the attics, rewiring outlets, digging trenches to check underground cables integrity.
In my many years working in maintenance, I am not aware that this was ever done. I would like to know if this is required by any code.
RE: Testing & Inspection of Electrical Wiring
Bill
"Why not the best?"
Jimmy Carter
Digging things up seems like a (very) bad idea. Report: The cable was good, right up to the point where the back-hoe tore a hole in it.
