Drilling holes in components without effecting the actual part
Hi all,
I have an assembly in which i want to drill holes for some of components as an assembly feature. But this should not disturb the original part(of component). Can you please suggest the best way to do this?
Thanks in advance
RE: Drilling holes in components without effecting the actual part
create the holes as clinders then...
 use insert-> combine->assembly cut
You could link the solids in the assembley and add the holes to the linked body.  They will not appear in the components.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
... or use promotions and add the holes.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
uwam2ie got it right the first time!  Use 'Assembly Cut' as that's what it was designed for.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
