Vacuum pump question
Hi all,
I would like to ask if your vacuum pump has water within. I assume it will fail to operate correctly. In this case, is there any method to dry the vacuum pipe?
RE: Vacuum pump question
Mine doesn't much care for water.
You didn't tell us what kind yours is, so I can't advise about that.
Mike Halloran
Pembroke Pines, FL, USA
Johnny Pellin
Other types will run without liquid (sliding vane, rotary, etc).
In other words, it depends.
