Welded 316L part, NACE MR0175 Compliancy
Hi everyone.
Sorry if this looks like a duplicate subject; I know there are lots of other threads regarding NACE MR0175, welding and PWHT requirements, but I couldn't find a clear answer to my problem in any of them.
Here's the deal: we are manufacturing 316L thermowells which are to be compliant with NACE MR0175. The raw materials are NACE certified, but they need to go through some fabrication procedures such as welding and turning.
As for welding, the standard only states that the hardness of weldment, HAZ, etc. needs to be lower than 22 HRC and that the carbon content needs to be < 0.03%. But it doesn't say (as it does with martensitic stainless steels, which need to go through a PWHT at 621 deg. C) how to achieve this hardness value. Is it enough to conduct a sample section test as instructed by ISO 15156, after our as-usual PWHT?
Also, will the turning induce any non-negligible cold work on the part? How about tapping?
Thanks!
Thanks!
RE: Welded 316L part, NACE MR0175 Compliancy
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
So, if the hardness test of the sample(s) turn out to be OK, there will be NO need for solution annealing the whole part again, right?
