Contact in Abaqus
Contact in Abaqus
The main problem I am facing in my model, is that when running the model the analysis can take over 30 minutes and there is a warning that says "There are 2 unconnected regions in the model."
This is the model that I have created. There is a UDL on the beam and the endplate is fixed at the edges to simulate a weld and the block is also fixed to simulate a column. I have created a contact surface with the master being the block and slave being the back of the endplate, the interaction is frictionless and is surface to surface. I created this model to simulate the endplate being able to warp into the (-Z)axis but will contact the block if it warps in the (+Z)axis. I have created a step using the default settings and the mesh is set to 4.
Could anyone please tell me what I am doing wrong?
Thank you.
Thank you.
RE: Contact in Abaqus
Tara
http://tinyurl.com/4ydjg7m
Does anyone know what I may be doing wrong. It just isn't analysing the job that I created
The reason the job takes so long may be due to the number of elements you've used. If you want to keep that number then let the job run a bit longer until you see an error message or at least until you see it cutting back to some small time step.
Personally I wouldn't assume that the plates would make contact at all and that the welds take all the load, as you can't be sure there isn't a gap there when they welded it up. In addition I wouldn't fix the end of the weld either as it's not fixed but attached to the other block, which will also deflect.
Tara
