Is fujifilm pressure film the same concept as articulating paper?
Is fujifilm pressure film the same concept as articulating paper? what are the differences?
RE: Is fujifilm pressure film the same concept as articulating paper?
If the pressure sensitive film you are talking about is this stuff:
http://www.sensorprod.com/pressurex_micro.php
Then the simple difference is:  articulating paper just shows points of contact by smearing of the inked/waxed/dyed surface.  The pressure sensitive film changes in density in a manner proportional to the surface pressure applied.
nice... thanks a lot
Articulating paper is what your dentist uses when he wants to "shave" off a tooth so your bite will fit...
