Curing conditions - EPDM
Hi All,
Is there a limit to the temperature EPDM should be cured at?
Would the max temp change depending on the method of manufacture (compression, injection or extrusion (hot air and microwave))?
Is the max temperature more related to the breakdown of any sulphur cross links rather than the polymer?
Elastomatt
Elastomatt
RE: Curing conditions - EPDM
1) is this happening due to starving extruder head if so then why the 2nd profile is not small?
2)Or is this b/c of flow balancing is not same on both cavities?
could anybody answer that?
