API 653 minimum thickness vs API 650 design thickness
Why does API 653 provide a higher allowable stress than API 650? The equations are equivalent except for E which is = 1.0 for butt joints.
The tank i am inspecting was constructed to 650 edition 9 appendix F.
It was NOT constructed to Appendix A.
It is 60 ft dia 32 ft tall (4 rings).
t = 0.216 for API 653 and
t = 0.232 for API 650.
The design specific gravity is = 1.5.
A-36 material
Ambient Pressure and Temperature
A-36 material
RE: API 653 minimum thickness vs API 650 design thickness
That being said, they do have larger allowable stresses for A36 in API 653. I think the reason being service history they feel they can cut into the margin?
Anyway, I put an API 650 calculator online and was looking for feedback. I placed it at
http:/
Any constructive criticism/feature requests would be useful.
Jeff Brubaker
Using my handy-dandy 653 calculator, I get 0.313" for A36 at 23.2 kips [1-ft method]
brubaker's calculator spit out 0.3026"
Nobody is close to your .216"/.232"
API 650
Calculating Thickness Per 1FT Method on Course1
Course1
D:60.0
G:1.5
S:23200.0
E:1.0
Cas:0.0
currentHeight:32.0
2.6xDx(H-1)xG/(SxE)+Cas=0.312672413793
Min Plate for 60.0, 0.25
Calculating Thickness Per 1FT Method on Course2
Course2
D:60.0
G:1.5
S:23200.0
E:1.0
Cas:0.0
currentHeight:24.0
2.6xDx(H-1)xG/(SxE)+Cas=0.231982758621
API 653
Course1
D:60.0
G:1.5
S:23200.0
E:1.0
Cas:0.0
currentHeight:32.0
Course2
D:60.0
G:1.5
S:23200.0
E:1.0
Cas:0.0
currentHeight:24.0
Min Plate for 60.0, 0.1
Course1
D:60.0
G:1.5
S:24900.0
E:1.0
Cas:0.0
currentHeight:32.0
2.6xDx(H-1)xG/(SxE)+Cas=0.291325301205
Course2
D:60.0
G:1.5
S:24900.0
E:1.0
Cas:0.0
currentHeight:24.0
2.6xDx(H-1)xG/(SxE)+Cas=0.216144578313
