ISO GD&T vs. ASME GD&T
What do you think about discussing more in details about differences between ISO and ASME GD&T? What are the most important discrepancies between the two in your opinion?
ISO GD&T vs. ASME GD&TISO GD&T vs. ASME GD&T(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: ISO GD&T vs. ASME GD&T
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Here is a content of paragraph 4.1 from ISO 1101:2004 - one of the most important standards from the group of ISO standards:
"Geometrical tolerances shall be specified in accordance with functional requirements. Manufacturing and inspection requirements can also influence geometrical tolerancing. NOTE Indicating geometrical tolerances on a drawing does not necessarily imply the use of any particular method of production, measurement or gauging."
Doesn't this look similar to Y14.5's fundamental rules 1.4(d) & (e)?
Isn't a general purpose of GD&T (regardless whether it is ISO or ASME) to minimize rejections / maximize "good parts"?
John-Paul Belanger
Geometric Learning Systems
Chris
SolidWorks 10 SP5.0
ctopher's home
SolidWorks Legion
"All features on component parts always have a size and a geometrical shape. For the deviation of size and for the deviation of the geometrical characteristic (form, orientation and location) the function of the part requires limitations which, when exceeded, impair this function.
The tolerancing on the drawing should be complete to ensure that the elements of size and geometry of all features are controlled, I.e. nothing shall be implied or left to judgment in the workshop or in the inspection department."
Could somebody identify if it comes from ISO or ANSI/ASME standard, or somewhere else?
Are you refering to ISO2768-Part 1 section 6 (and clause A4) along with ISO2768-Part 2 section 7 (and A4 again)
"Workpieces may be whatever shape the manufacturer decides, the designer has no say in the matter unless it's totally fubar"
Has to be my favourite part of any standard
Apologies if you punch anyone as a result of me looking it up for you.
Designer of machine tools - user of modified screws
Ninja, could you back me on the fact that 2768 is very limited in scope, as it only applies to dimensions without tolerances usually typical for "non-critical" features?
And in fact, it doesn't apply to "invisible dimensions", such as hidden inside of 3D-model?
And also it doesn't apply to reference dimensions and basic dimensions?
And also it doesn't cover cylindricity, profile of any line, profile of any surface, angularity, coaxiality, positional tolerances and total run-out?
And it still your right (and responsibility) as a design engineer to:
Explicitly indicate smaller tolerances than 2768 on the drawing when required for proper function?.
Explicitly indicate larger tolerances than 2768 on the drawing when permissible for economical manufacturing?
Explicitly indicate that your favorite (sorry, favourite) section 6 (and clause A4) do not apply?
Another difference between ISO and ASME is that ASME tolerances are nested, or inclusive. As you work down a stack of controls on a feature, each subsequent control must be a refinement of the preceding control (i.e. a smaller tolerance zone). With ISO, each control is considered separately and therefore you could for example have a parallelism of 0.1 with a flatness of 0.5. In other words, in ISO the tolerances are cumulative. As an extension, within ASME the surface finish/roughness is considered a refinement of the surface form; within ISO, the surface roughness is cumulative, so it can actually exceed the flatness.
Overall, ISO seems to be moving to a metrology-based standard. The definitions of the various controls indicate means of checking the control rather than focusing on the functionality of the control. ASME has always been functionality based and with 2009 moved even further from including any instructions on verification.
The differences between the standards is a big topic.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
Also, I don't think ASME sees surface roughness as a refinement of form. You could have a crowned surface that fails flatness, yet its surface roughness could be as smooth as glass.
John-Paul Belanger
It is interesting what you are saying about relationship between values for parallelism vs. flatness tolerance (0.1 vs. 0.5). I know you used this as an example only, however I am really tempted to not agree with you.
Paragraph 5.2.2 of ISO 2768-2:1989 "General Tolerances for Parallelism" states that: "The general tolerance on parallelism is equal to the numerical value of the size tolerance or the flatness/straightness tolerance, whichever is the greater."
Doesn't this mean that parallelism value must be at least equal to flatness value?
This is because actual surface roughness is a refinement of actual flatness error. But the opposite situation can't happen, and this is, I believe, what Jim meant.
Also, a surface can fail surface finish and yet pass flatness.
I guess the confusion is because the parameters for surface finish are localized (the cutoff width), but flatness spans the entire surface all at once.
So in this regard, both ASME and ISO see flatness and surface finish as separate requirements, which was my intent in replying to Jim.
John-Paul Belanger
Allow me to disagree.
"Within ISO, Rule #1 does not apply (unless specifically invoked)"
All you need to invoke Rule 1 in 2768 is to add (E) symbol to the call-out, just once on the entire drawing sheet. ISO is well aware of Envelope principle and puts it to good use.
"ISO 2768 deals with the size of a feature, not its form. I've heard arguments to the contrary, but nobody's backed it up from the ISO 2768 standard"
ISO 2768 covers Flatness, Straightness add Circularity which ARE form controls. Nobody will "back" it for you, open the book and see for yourself.
"With ISO, each control is considered separately and therefore you could for example have a parallelism of 0.1 with a flatness of 0.5"
Entirely not true. In ISO location and orientation tolerances also control form characteristics. In your case flatness may be indirectly controlled by the Envelope requirement, Perpendicularity, Parallelism, Angularity, surface Profile, Position, Total run-out, and general tolerances, like ISO 2768.
"As an extension, within ASME the surface finish/roughness is considered a refinement of the surface form; within ISO, the surface roughness is cumulative, so it can actually exceed the flatness"
Wrong again, flatness specification could limit surface waviness or roughness, it's just no one cares because form tolerances are much larger that surface texture specs.
Doesnt mention dimensions in a 3d model (the standard is from 1987, its likely this concept didnt exist at the time).
Doesnt apply to reference (auxiliary in the standard) or basic dims.
Doesnt cover cylindricity but implies cylinders are controlled by circularity and paralelism, which the standard does cover. Profile of a line and surface are covered lightly by straightness, flatness and paralelism. Angularity no but it covers tolerances on angular dims. Coaxiality is not covered but coaxiality may be limited by circular runout which is covered. Positional tolerance and total runout are not included.
The last three are correct, what use is a designer who doesnt control tolerances which improve the design. The last bit of the standard is right when interprited correctly and common sense applied, it needs re-phrasing badly.
Next you'll be saying the bit ninja paraphrases is only in there to allow deviations/waivers etc.
Plus 2768 gets misused the same way block tols and the like do - though arguably that's not the fault of the standard itself.
Almost nothing is being said above that hasn't been said before in earlier threads on the topic.
PMarc, the citation from 2768 is a good example of ISO double-speak. ISO (1101?) indicates that size and form must be controlled separately (as a default method), yet here they are implying that size also controls orientation? Orientation wrt what? ISO 2768's not valid for orientation control because it doesn't require the definition of a datum reference frame. I have seen people work around this by putting a generic note such as "GENERAL TOLERANCES WRT DRF /A/B/C" In 2768, does ISO treat parallelism as a localized thickness control? I've never been able to have an ISO-trained person answer that question and support a datum reference requirement per elsewhere in ISO GD&T standards.
I retract my earlier statement about ISO controls being cumulative. Per ISO 1101:2004(E), Section 17 Interrelationship of geometric tolerances; "For functional reasons, one or more characteristics can be toleranced to define the geometrical deviations of a feature. Certain types of tolerances, which limit the geometrical deviations of a feature, can also limit other types of deviations for the same feature. ... Orientation tolerances of a feature control orientation and form deviations of this feature and not vice-versa. Form tolerances of a feature control only form deviations of this feature." Looking at the '83 version, this was covered in less detail in 13.2. Interestingly in '83, figures 36, 37, 44 & 45 show parallelism to a surface without a datum reference, but rather with a datum triangle anchored to the "reference' surface.
But I now agree that if someone were to create a roughness callout of 0.5 microns (with the cutoff width being the same as the full length of the surface) and a flatness tolerance of 0.0000006 mm, then we have a problem (both in terms of mathematics and practicality).
John-Paul Belanger
The ASME standard seems to be backing farther and farther away from the certainty it seemed to provide in 1982. I believe this is good as it was a myth anyway. Many tolerances no longer cover a FOS anyway but an AME, and we talk about them defining by abstract concepts. We do not use a lot of gauges here at my company all CMMs.
As far as ISO 2768-1's paragraph I believe that is a bunch of fuss about nothing, we accept parts out of spec every day, all this says is we can and will if it occurs on features covered ONLY by the general tolerances, it does not use "fubar" that is an incorrect quote added to put something in a bad light.
I really wish some of these ISO people would come on here and defend it themselves I supose we would need to be able to read German.
As far as the thickness of the ASME book well I have seen discussions here wanting to through out examples that have been in the book since 1973. After everyone here throws out the parts they don't like, the ASME standard might not be as thick and may even look like the ISO standard just showing general concepts and letting it go at that.
Frank
"ISO 2768's not valid for orientation control because it doesn't require the definition of a datum reference frame"
Wrong once again. Parallelism requires one and only one datum – have you ever heard of being "parallel to A, B, and C"? And for this datum 2768 picks the largest of two features – smart and simple.
So, yes indeed, THERE IS datum reference frame – just enough of it.
Note that 2768 is carefully avoiding controls that require more than 1 datum – position, profile, etc. One should agree that 2768 is too smart for what essentially is glorified tolerance sticker.
And "double-speak" is a harsh word. One day your company may have more ISO clients than ANSI/ASME clients. Just a thought.
As I recall it does attempt to define how to apply the form type tolerances. if it is not perfect well niether is ASME I reference the disagreements here on Fig 6-18 or 6-52 and as far the comments on taloring a tolerance to an inspection method, who can look at runout, Yes I know it doesnot have to be checked that way.
Checker Hater,
I like you more and more. I have a feeling we have had a similar experience somewhere, First, I want to say, I learned a lot from checkers and consider some were my friends. However, when I was trying to convert our system to GD&T (1982 standard) they were the ones most against change, as they liked the old way, it made them powerful. "my" GD&T threatened all that. The entrenched buracracy won that battle, company went out of buisness soon after I left.
Frank
Frank
Overall, what I've seen is a cleaning-up of many of the outstanding issues in ISO's GD&T standards collection. That's a sentiment shared by many in the ISO user community as well. And, I've used stronger language in comments about ASME's GD&T standards.
The out come being that the drawing no longer defines what is an acceptable part.
Where on this am I mistaken?
ASME put's the drawing originator in the driving seat. If a vendor or whoever wants me to accept a part that doesn't explicitly meet drawing then I get to decide if I want to spend the time and effort ($) looking into the defects and how they affect function (above and beyond that already defined on the drawing) and if they can be recovered... They can't force me to do so.
However, the ISO 2768 way, the drawing originator has to justify why it can't be recovered. I have to justify why I won't accept parts that don't meet my stated requirements. Whether I want to or not I have to spend the time to justify not taking them. Am I meant to have some other document besides the drawing that captures this? In the end who decides if my justification is adequate?
The ISO 2768 sure makes it easier to ask forgiveness than ask permission - forgiveness is the default state and not forgiving has to be justified. Though I suppose in a way that almost makes it Christ like.
On the plus side for ISO, I think that they're way ahead of some of the metrology and math-definition aspects compared with ASME.
Sorry,
I believe you, and maybe some others around, may feel that this statement captures, in your opinion, the essince of the referenced statement, but, it is NOT a "TECHNICALLY" corect ISO statement. Any representation as such is incorrect. I would expect more persnicityness (is that the word I want?) from a real technical discussion, particularly from a checker (sorry, I had to say it).
I feel it my duty to any of the "uninformed" here to call it out as such. Understand, I believe the ISO standard is not perfect either, but I will say the more I learn the more I like it.
Frank
The ISO standard just recognizes that too many GENERAL tolerances are not based on practical absolute requirements. The basic supposition that they spell out is that it is not practical to control every dimension to the absolute extremes when process will GENERALLY hold them much tighter, did you read that part too? If you make millions of the same thing it may be worth the time to check, but in many cases it is not justified. Why don't your inspectors check EVERY point of EVERY feature? I suppose there are some that actually think they do?
So if I am not going to check every single dimension to it's absolute extremes, it is only a rational buisness decision to say don't throw the part away unless it will not work. I believe this is a rational position to take give the premise they have laid out
There are some here that will say "they" have checked all of theirs, well good for you, yours are fine then. I am here to tell you most do not. I have been around too long and worked at too many places to believe it. I have even seen some admit it here.
As we have stated here, before, in this area the ISO is covering areas not covered by ASME and when they have attempted they just basically adopted the ISO's work (ref: ANSI B4.3).
Frank
I believe the approach difference is a key to everything here. And I wouldn't even try to judge which one is correct and which is not. In fact, in my opinion, there are strong and weak points in each of them. And what we shouldn't do for sure is to arbitrarily assume that ISO standards (in this case 2768) are bunch of useless junk without any logic behind - they have been created by people with tremendous amount of experience and practical knowledge.
Here are some of my other thoughts:
I still do believe that ISO standards in general are oriented for 'functional design' even if some paragraphs may sound otherwise. The point is that ISO additionally pays a lot of attention to how the part is manufactured and even more to how it should be inspected. But is it wrong? I wouldn't say so. For me the functionality is not only a question whether something will assemble with something else. It is a matter of manufacturing abilities and economy too. One can have perfectly 'functional' assembly but the effort put on manufacturing and on the inspection will generate such a high price that at the end nobody will think of this product well. As usual, the compromise has to be found, and this is one of the purposes of 2768 standard - it is trying to tell that with this kind of tolerances a design can be economically optimized, adjusted to manufacturing and inspection abilities of a workshop.
But unfortunately this is a noble theory, nicely described in the annex A of both parts of 2768. The reality shows that 'general tolerances' concept is so general and broad that it had to be boiled down to some relatively simple cases and even with that it gets quite unclear. Example: take the general symmetry tolerance for instance - ISO 2768-2 is saying that: " The longer of the two features shall be taken as the datum; if the features are of equal nominal length, either may be taken as the datum." That is clear, but what if there were 3 features of different length shown nominally symmetrical? Which one should be chosen as the datum? Figure (b) in annex B5 is showing such a situation but not explaining how the third feature should be controlled. Should the two shorter features be controlled wrt the longest one or should there be two different datums for two positional callouts?
This was an example only - all I am just trying to say is that the standard is not perfect and leaves plenty room for assumption, but that is life. For some of us it can be useful, for some can't. I saw drawings of really complex parts with almost no geometrical tolerances shown but stating that general tolerances are according to ISO 2768. You would not even imagine how much time a product engineer spent on explaining to inspector which geometrical characteristics should be measured relative to which features. They finally found an agreement but only because they were working in the same plant and were speaking the same language, so they sat together with their bosses and clarified all the issues. Can you imagine what would happen if one was speaking American English, the second one Chinese English and they were located thousands miles apart?
And just for the end, despite of all shortcomings of ISO standards (not only 2768), I agree that they have one big advantage over Y14.5 and associated documents - they are way ahead in mathematical definition of inspection routines for geometrical tolerances. I fully respect and admire Y14.5 for its versatility in describing so different dimensioning and tolerancing schemes within one document, but the fact that those concepts are not fully supported by mathematical definitions is one of its biggest weaknesses.
This thread was created to COMPARE ISO with ANSI/ASME.
Did anyone notice that there is no general tolerance ASME standard AT ALL?
So, there in nothing to compare. There is a "bad" standard vs. no standard.
"The outcome being that the drawing no longer defines what is an acceptable part"
No, drawings don't define it, engineers do. If due to laziness or lack of professionalism someone forgets to attach tolerance and/or geometry requirement to critical feature, 2768 will come back and bite him in the leg. I have no problem with that.
Sorry for all the bitterness, it's a bad case of Mondays.
And on the lighter note:
"How 'bout the fact that the ASME standard is one volume with a cost of US$170, but for ISO you have to buy scads of separate standards where the total cost gets into several hundred dollars!"
Have you ever seen commecial for Stella Artois beer? "Perfection has its price"
For years on this forum ISO criticism was limited to 2768 and price of Y14 book. How 'bout something new for a change?
ISO 1101 declares Independence principle by default. It's a small standard - about 7 pages. 4 of them are dedicated to explaning Envelope principle. How much of Y14 is dedicated to explaining Independence? Could that be the reason ANSI/ASME guys fail to understand ISO guys more often than the other way around?
ISO allows you to invoke Y14.5 on your drawing and be compliant still. Is thre any place in ASME that allows use of "foreign" standard?
And speaking about difficulties of understanding: Apparently you don't fully understand Y14.5 unless you buy Y14.5.1 on top of $170 yo've already spent. How's that for double-speak?
John-Paul Belanger
Say whatever you want about checkers, our place 'saw the light' a couple of years ago and I no longer get that miserable task, except when someones drawings are so bad that even management can't divert the blame. Now I even get to do some project management so I could play the other side of the fence if I really wanted.
I believe there was an ASME equivalent to 2768, which was indeed a din originally. I think it's been brought up before, or maybe I'm imagining it.
I've already said that using 2768 incorrectly is comparable to using the typical inch block tols incorrectly. Though, one might incorrectly think they were doing a better job simply by referencing a 'standard' than relying on some fairly arbitrary numbers on a drawing template or similar.
The first few years of my career were in the UK to iso standards, so any implications of nationalism are questionable.
Finally, the implications that using 2768 is analogous to the whole 'critical dimension' debacle is scary stuff - enough to make me like it even less.
"complete and comprehensive solution to the never ending problem of most designer not being willing/able to spend enough time & effort to properly tolerance drawings" is to fire the bastards and replace them with knowledgeable skilled professionals.
Bad drawings cannot be improved by magically applying some "fairy dust" to them, be it genius-written Standard to invoke, or Tolerance sticker made by Elves.
At the end of the day everything is made by imperfect people. And guess what? I spent number of years in a machine shop. We were producing new part every day (or night), so I had literally hundreds of prints going thru my hands. In all those years one single drawing made by some government sub-sub-contractor would qualify as "standard-compliant". The rest was Creative drafting, or complete fubar which is fashionable word on the forum today. There was never one unsatisfied customer. Period.
The truth is: One can make a living by producing good parts from the bad prints, and at the end of the day its all that counts.
Don't try to save the world by application of general tolerances.
I am old and I am tired. Next time let me offer Ken my help - I will be holding people that he will be punching.
You should know the above statement is not correct as written in the ISO standard. It is an exaggeration for dynamic effect.
You are quite correct: ANSI B4.3 General Tolerances for Metric Dimensioned Produts.
The German reference was not in reference to you and your heritage, but from the fact that, we both know, this standard is basically derived from the DIN (German standards) version.
Jim,
The problems you see in the general application of the ISO standard are in my opinion related to the same problems I see with the ASME standard. While ASME does not cover general tolerances like ISO in the same way, they do try to cover the meaning of how to interpret implied general tolerances. We seem to see a progression of statements in the standard over the years to less certainty of intent of the old implied tolerance dimensions. They basically are recommending using the "new GD&T" system for better coverage in stronger and stronger language but refusing to pull out the rug completely. So I think the real problem is they are retroactively trying to give a clear definition to what is an already an acknowledged imperfect system.
Frank
I agree, again we are really working in an imperfect world. I am not suprised at all about the caution, either. I believe it would only cause more resistance to adopting the standards than there already is currently. We still live in 1982.
Frank
It will be fools like me who think latest and greatest stuff will get them somewhere.
I am all for keeping up, myself, I have been pushing for it. In my years of experiance change does not come easy to bureaucracies. I would venture to say it even scares them.
Are you the boss?
Frank
Given current state of economy no-one will retire at 65, so there is metric ton of time ahead.
Maybe part of my concern is that much of early GD&T as I understand it came out of the need/desire to ensure interchangeability, any part 'A' would assemble to any part 'B' and this is still a major factor to me today. This is still what ASME with it's emphasis on worst case & drawing defining an acceptable part seems to lean towards.
The thing with not relying on the functional needs as summarized in an ASME drawing is what happens if it's a spare part for instance. If function is defined as being able to be assembled, well because you aren't assembling it straight away how can you tell if it's a good part?
If function is based on some strength requirement, then you potentially end up having to run some calculations, doing FEA, or maybe even proof tests... Now I'm sure many of us have been involved with approving deviations/waivers/concessions etc. which required some of the above, however the iso 2768 para 6/7 forces you to do it as I see it.
Of course, then there's the statistcal tolerancing approach which is already a deviation from true interchangeability but widely practiced and accepted.
Just some incoherent musings, sorry.
Frank
All the parts have Fit, Form and Function requirements, but every feature is "biased" towards one of them.
If you are in America you probably have a car. Think of the wheel.
The interchangeability is achieved thru fit and form requirement.
Wheel has mounting holes that have to "fit" over the studs (by diameter), there is a position requirement for wheel to fit on certain model hub. The cone countersinks on the holes probably controlled by really crazy GD&T (everybody hates cones, right?)
And then there are vent holes with the sole "function" to let the air to the brake rotors. There is no fitting part.
The dreadful clause only applies to vent holes. In fact, there are many wheels that look different, but are actually interchangeable.
Disclaimer: not a wheel designer. Things are probably more complicated (balance, etc.) Just trying to make a distinction between things that have and don't have to physically "fit", but both have a "function".
I believe that is incorrect. The drawing per 1011, 5459, & 8015 defines an acceptable part; not the "tolerance unless otherwise specified." I think you are taking that part of 2768 way out of context.
Joe
SW Premium 2011 SP3.0
Dell T3500 Xeon W3505 2.4Ghz
6.0GB Win7 Pro x64
ATI FirePro V5800
a bit incorrect, it is ISO 8015
Not everygody hates cones ... they are actually a specialty of mine due to my mold-design origins. I actually had one instructor tell me that it was impossible to use cones as datum features and that we would have to redesign our molds to use flats & cylinders ... don't think so. Cones can be a challenge for those that don't know/like/understand profile of a surface, but they're easy once you go that way.
My bad
Jim,
There are heated discussions happening about what cones are good for.
Will be glad to see more of you on this forum
Iso 2768-1 6. Unless otherwise stated, workpieces exceeding the general tolerance shall not lead to automatic rejection provided that the ability of the workpiece to function is not impaired (see clause A.4).
Iso 2768-1 A.4 The tolerance the function allows is often greater than the general tolerance. The function of the part is, therefore, not always impaired when the general tolerance is (occasionally) exceeded at any feature of the workpiece. Exceeding the general tolerance should lead to a rejection of the workpiece only if the function is impaired.
I get the idea that the general idea is that the 'general tols' are meant to be so 'loose' that they should easily be met. However, I don't fully buy into what it says in A.3 about reducing the need to do detailed tolerance calculations. I don't see how it helps guarantee parts will fit or similar which is when you do detailed tol calcs typically.
Perhaps, if you're using the spec properly, any directly functional dimensions are actually fully specified on the drawings, while only those that are effectively in 'free space' or similar fall under the 2768.
However, I've never really seen it used this way - though as I've conceded before, in this extent it's comparable to block tols being misused.
