Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...just the few hours I've spent on this site I have learned a lot. I can now implement features that will be very useful to my company, and some of those I never knew existed..."
Geography
stevenal (Electrical)
25 Aug 11 14:59
A fan comes with installation instructions showing it installed with two switches. One switch is a master power switch, the other allows the user to select between the maximum speed and a lower speed that can be set on the fan itself. The installer installs the master switch and connects the remaining two wires together so the fan is either on full speed or fully off. By disregarding the instructions, has the installer violated listing and therefore violated NEC? Thanks.
dpc (Electrical)
25 Aug 11 16:20
Unless the installation instructions show or describe an option for installing without the speed switch, I can see it being an issue with some inspectors.
Perhaps some correspondence with the manufacturer/supplier might help.
David Castor
www.cvoes.com
DRWeig (Electrical)
25 Aug 11 17:04
Stevenal, it sounds like (but isn't clear to me) the two switches are external to the fan?
If so (external switches), you're not violating the listing -- a wire nut can serve as a permanently-closed switch.  UL listing doesn't extend past the end of the lead wires. The fan is "as tested" at UL unless you open it and change something. (I have done this exact thing before, as engineer of record in a bunch of schools -- I actually drew the wirenut on the plans.  No problem with electrical AHJ in Memphis). Of course, you should check with your own AHJ for a final ruling if you're in a quandary.
If not (switches mounted in the fan housing and wired at the factory), you're violating the UL to open it and jump out the switch.
Good on ya,
Goober Dave
DRWeig (Electrical)
25 Aug 11 17:05
Oops I forgot my disclaimer, "In my humble opinion, based on my personal experience, ..."
But you two posters above me are old-timers, so I'll not worry.
Good on ya,
Goober Dave
25 Aug 11 17:36
The switches are external.
I must disagree that the listing does not extend past the wires. Certainly it would violate the listing to hook it to the wrong voltage or operate it it the wrong atmosphere.
No wish to involve an inspector at this stage, just collecting ammo to attempt to get the installer to do it right.
dpc (Electrical)
26 Aug 11 11:44
If you want the switch, I think you can make a pretty good case that the installer did not follow the manuf. installation instructions, so UL listing is void and the installation is a violation of NEC.  I don't think it is a safety hazard as installed, but that's a different question.
David Castor
www.cvoes.com
Close Box
Join Eng-Tips® Today!
Join Us             Close
