3D Sketch Pattern
3D Sketch Pattern
3D Sketch Pattern
Hello All,
Is it feasible to do a circular pattern for a 3D sketch?
RE: 3D Sketch Pattern
No, but if you need a pattern in a 3D sketch, you can created it in a regular sketch and then use the convert entities command to transfer your pattern from the 2D sketch to the 3D sketch.
