Find area of face in mm?
I am trying to work out the area of all the faces on a model.
I see you can do this by measure inertia and measure item.
The answer always appears in m^2 and rounds it off to 3 decimal points, is there a way to give the exact answer in mm^2 or give the exact answer in m^2?
RE: Find area of face in mm?
Tools + Options + General + Parameters and Measure
in the UNITS tab; scroll down to AREA and choose whatever units you want to use. Lower down in the same panel, you can set the DECIMAL PLACES FORE READ/WRITE NUMBERS if you want something other than 3
Got it:
Tools > Options > General > Parameters and Measure > Units
Any magnitude here can now be altered to suit your specification
You just beat me to it :). Thank you for your help Jack
One more question.
I'm not sure what the problem is here, but I don't think that the measure tool is calculating the correct area for me. It says 1200mm2 for both faces but 1 face is clearly larger than the other.
"Face" contains the correct area of 1200mm2
I have included a screen shot
Sorry I am incorrect, the computer wins
it usually does
