NaHS Storage Tank
NaHS Storage Tank
NaHS Storage Tank
I'm designing a NaHS storage Tank. I want to know what are the basic recommendation for this kind of reagent tanks.
Specially I want to know the vent system, drain and overflow.
I saw some picture with a special vent system but I don´t know how it works.
I'm considering Carbon steel material, maybe stainless steel. all piping in stainless steel 316L.
Thanks in advance
RE: NaHS Storage Tank
Special venting and fire protection requirements are necessary for NaHS storage. Locating the tank one zip code away from people may be a good idea.
NaHS tanks can be poisonous fume generators if engulfed in a fire
I guess you don't have access to GOOGLE in your country....this was my first hit when searching for "NaHS storage"
http://www.tdc-home.com/downloads/NaHS_NaOH_Handbooks/3%20Flammability,%20Fire%20Response%20&%20Storage.pdf
Where will this tank be located ? What active volume is required ?
Is this the first process chemical storage tank that you have "designed" ?
I believe that the best tank material would be Nickle 200.....
