"Use Corner data" option in FEMAP
Hello all,
I have a doubt related to postprocessing results in Femap. I've made some estructural linear analisys and I've found that exist great differences in stress values in some little areas (where stress concentrates) if you active or not the corner data results. Actually, without corner data results I can get some reasonably good results and with corner data results I get little peaks of high stress (maybe 100 MPa higher), specially in some vertex(even in areas with a fine mesh).
Do you recommend me having into account all data for postprocessing results? Or maybe this high stress peaks in little areas don't exist in the real model with this values?
I have to say that without corner data results I get a more 'homogenous' stress concentration in these areas a with a lower value...
Thanks so much in advance.
Jose
Jose
RE: "Use Corner data" option in FEMAP
However I would like to know the convenience of having in account the "corner data results" in these cases. Maybe it's more realistic to activate only the elemental data results when mesh is not very refinated??
Best regards!
dumb question ... you have checked for coincident nodes ? (and removed them)
At last, I have the feeling of not to be getting realistic or accurate results...
What do you recommend me, to have in account 'corner data' being conservative or trying to remesh with a fine mesh in this area and check again?
On the other hand, I don't have pictures in this moment because it's an enterprise project and I'm at home right now. Tomorrow I will upload an image(A picture is worth a thousand words...)
In the first one I have the postprocessing only considering elemental data results. The stress distribution is smoother in the area close to the inferior corner and the maximum von misses stress is 263 MPa, what is under the Yield tensile strenght for S275 Steel. Safety factor is very reduced, but well, anyway.
http://fil
On the other hand, I have the postprocessing considering averaged corner data results. In this case I get a maximun stress of 324 MPa, what is over the Yield tensile strenght. As well, the stress transition is faster in the corner element.
http://fil
The difference of the max values between this two postprocessing results is more than 60 MPa (what is a lot!), and that's the reason because I'm a bit confused and can't believe in the accuracy of the results...
i think your pix clearly show what is happening. in pic 2 you have imported nodal stresses, so the program can plot them. ie the stress peak at the corner node is imported and plotted. in pic 1, using only element data, the program doesn't extraploate well from element centroid to the edge (i think it is extrapolating from one element centroid to the next and projecting this tragectory into the corner.
pic 2 is the better set of results. the fact that the FEA is predicting localised yielding isn't too much of a concern ... hand calc would never calculate it, the yielding wouldn't be evidient or detrimental to the structure. it is also due to the rigidity of the joint inherent in FEA; in reality there is a finite stiffness between the gusset edge and the shell (rather than the infinite stiffness moidelled by sharing the node).
I think it was really a refinement mesh problem in that area. Actually, I've remeshing the gusset with a smaller element size and I've observed that both elemental centroid results and nodal results converge in similar results, so you were right when said that pic 2 shows better results.
In another hand, nodes in left side of the gusset are common to the ones of the tube and I've connected low nodes of the gusset with the base using RBE2 elements with 6 DOF fixed (in NX Nastran it represents infinite stiffness elements, so it's the same that sharing the node). Would you have modeled it in other different way? Maybe extending the gusset until the base and sharing common nodes?
As well, you have said something interesting: "the fact that the FEA is predicting localised yielding isn't too much of a concern ... hand calc would never calculate it, the yielding wouldn't be evidient or detrimental to the structure". Why do you think that this localised stress wouldn't take place in a real model only because a hand calculation doesn't take it into account? If what you say is true, I should rethink many concepts realated to postprocessing and validating a model using FEA...
Mechfeeney, I consider distortion in that elements is not very high. In fact checking both the alternate taper and internal angles I get some good enough ratios (internal angles < 30º and alternate taper < 0.05) so I think the main problem was not elemental distortion but mesh size.
http://fil
As well, you comment that there is something strange in that model. What are you referring to exactly? Well, I have to recognize that I'm relatively new in fem and maybe I'm making something wrong...
Remember, when you define the "NASTRAN Output Request" you have an option at the base of the form that you can switch ON/OF named "element corner results", when ON then FEMAP will write the following in the nastran case control:
FORCE(PLOT,CORNER) = ALL
STRESS(PLOT,CORNER) = ALL
If OFF the nastran input will be as follow:
FORCE(PLOT) = ALL
STRESS(PLOT) = ALL
You can request corner outputs (stress, strain, and force) for CQUAD4 in addition to the center values with the STRESS, STRAIN, and FORCE Case Control commands. Corner results are extrapolated from the corner displacements and rotations by using a strain rosette analogy with a cubic correction for bending.
When you select "element corner results", output is computed at the center and four corners for each CQUAD4 element, in a format similar to that of CQUAD8 and CQUADR elements.
In summary, what I try to tell you is the SOLVER computes stress at the corner nodes, then is mandatory to activate "use corner data" when postprocessing stress results in FEMAP, not to ignore this data at all because the stress results are too high.
Another history (but closely related) is the quality of the mesh: I saw your pictures, not too bad, the mesh density in a finite element model has important implications for both accuracy and cost. I am of those that spend all the time required to prepare geometry (splitting surfaces, using pads, washers, etc..) to have the BEST quality mesh as possible, with the less distortion as possible (in case of shell elements the ALT TAPER to be less than 0.5 always!!). How fine a mesh you want depends on many factors. Among them is the cost you are willing to pay versus the accuracy you are receiving.
Compare solutions using different mesh sizes, you can always establish error bounds for a particular problem by constructing and analyzing multiple mesh spacings of the same model and observe the convergences, this is the way, comparison of results!!
And for linear analysis I prefer to state using CQUAD4 elements instead high-order CQUAD8, in general the results using CQUAD8 are better than those using the CQUAD4, yes, but results using CQUAD4 can, of course, be improved by increasing the mesh density to approach that of the CQUAD8 in terms of number of DOFs, and solution is faster.
Well, this is what I can share with you, good luck!.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
As well, with my current model, I've done yet what you say about comparing results with different mesh sizes and in fact, I guess observing convergences is the only way for checking the accuracy of a fem model.
Best regards.
Jose
