L4x4x1/2 A36 with 50 ksi rating clarification require?
I am working on an upgrade to a self support tower for telecommunication application. My steel shop is telling me that the required angle by the engineer, an A572 grade 50 ksi, they can not get, but instead they could use an ASTM A36 with 50 ksi grade rating. IS this true? If it is what kind of documentation I would need to see from my steel shop in order to make sure that the angle I am getting is actually rated to 50 KSI?
I have read that some steel mills are now dual certifying material to have this type of rating or specifications, how true is this?
Any help will be greatly appreciated.
Marcello.
Marcello.
RE: L4x4x1/2 A36 with 50 ksi rating clarification require?
A36 kind of went the way of the dodo bird about 15 years ago - almost all is now 50 ksi - at least for steel beams. Tube and pipe are different animals.
The only information I could find was an article on Modern Steel Construction MSC magazine dated back from 1999 in which it talkes about dual specs and mentiones table A of ASTM A6/A6M. But then again this is dated back over 10 years ago.
I did get the mill certs and not very happy. the A36 material shows a 48 ksi yield which is no good since I am dealing with an upgrade for a telecommunication tower, and not just that, it has a big "REJECT" note on it...Wonder what that tells me, right!? Fun Friday for me.
I think within the results you will find some comparisons of impact testing of the two if you can find one from Lehigh University where A-36, A-572 and A-992 were contrasted.
rmw
