Burst Test Calculations per UG-101(m) - Multiple Part Assemblies
I have an assembly I would like to burst test to ASME B&PV Code Section VIII UG-101(m).  The assembly consists of several parts, but is essentially two clamshell pieces held together in a flange type configuration with fasteners.  There are also several pipe pieces threaded into the clamshells that are under consideration for burst strength.
My question is, when I get a burst pressure result, how do I go about applying the de-rating formulas in UG-101(m)?  These are the formulas where you take the actual tensile strength of the material used and calculate a de-rated pressure, and then use this also in the temperature derating formulas.  Do I do this analysis only on the failed part, or do I apply the de-rating formulas to all parts (those that failed as well as did not fail)?
Thanks.
RE: Burst Test Calculations per UG-101(m) - Multiple Part Assemblies
Ask your Authorized Inspection Agency  (AI) they will usually guide you through your first Proof Test for a fee. (At least a worthy AIA would)
Also Try this link for guidance: http://www.pveng.com/BurstTest/BTGeneral/BurstTestGeneral.php
OF COURSE obtain the Code and read up on it. All the answers are there.
FAQ731-376: Eng-Tips.com Forum Policies A question properly stated is a question half solved.
Well, all the answers that are there, are there:)
