concertina effect?
concertina effect?
I have a piece of tubing that i want to replicate in solidworks using a thin sweep. However, it is a 'concertina' type of tubing i.e. when at full length is split into segments that compress together to halve the original size. The easiest way to describe it is like the body of a caterpillar! I'm wondering if anyone knows how I might be able to produce such a sketch? The only way I can think of is to skecth intermittent circles of varying diameter along the sweep curve and sweep to each one individually in order to get the desired effect. I want the tube to appear at its extended length. Is this the easiest and only way? Thanks.
RE: concertina effect?
BBJT CSWP
A Sweep with guide curves may be the better solution. I recall reading somewhere that sweeps are more accurate than a loft. But in the past I have had better luck with lofting with these types of parts.
BBJT CSWP
