Rosemount 3051 diff pressure transmitter - programming?
Hi Gents,
I often encounter the above showing an alternating display of "mbar" and then "Nl/min".
Can anyone explain in simple terms how the transmitter is programmed to generate the flow from the measured deltaP?
All help much appreciated.
Paul.
Paul.
RE: Rosemount 3051 diff pressure transmitter - programming?
See the manual.
htt
ATB,
Paul.
