Converting Images or word clip art into something acad can interpret
I'm in the process of building a title block, I'm trying to avoid drawing the whole company logo out by hand. Is there a shorthand way to take this piece of clip art from the word doc and convert it to something that acad can interpret?
Thanks in advance
Thanks in advance
RE: Converting Images or word clip art into something acad can interpret
The results better and file size much much smaller.
Screen capture the portion of the WORD document showing the logo using your PRTSCRN key on your keyboard. The image is now on the clipboard (from prtscrn). CTRL-V or EDIT-Insert it into the IRFAVIEW (or other) window. Draw a box around JUST the logo. Go to EDIT-CROP-Selection to isolate the logo. SAVEAS to a filename you think is appropriate.
Use ACAD's image insert commands to insert, scale, rotate and position as you would positioning any ACAD entity. For 99% of the cases you are done. Also, I'd place it on a layer I could lock easily, but that's just me.
Since you can have white backgrounds in your drawing tabs, this should work perfectly for you, since you're likely printing on white paper.
Good luck, and let us know how it went !
